stripped switch housing screw, re-thread?
I noticed one of my left switch housing is stripped -top one (must have been done by the previous owner) I am wondering if there is enough alum/plastic? around where the screw goes in to drill/tap one size bigger.
Other options are trying epoxy to fill, drill, re-tap or buy one from someone taking off for chrome. Anyone been here before?
RE: stripped switch housing screw, re-thread?
I've herd good things about this stuff http://doitbest.com/Repair+Kits-Perm...sku-576719.dib
Review housing.
On many housings the female end is actually threaded much deeper than bolt.
Then go to ACE hardware with bolt that was removed and purchase a bolt that is longer.
You should also purchase a nut to fit that bolt.
Place nut on bolt and cut bolt so it is about 1/4 inch longer than original.
Un-thread nut (this cleans the cut and threads).
Bolt should be good for application.
The way to make it like new is to use a helicoil insert. The thread size is a 10-32.
When finished, your fastener joint works just like it did when new.
I hate these screws, and the ones that clamp the clutch and brake lever. It is the stupidest place for a Torx head.
In reality, the Torx SHOULD work fine, but all of us tend to over-toque these screws and either strip the head or the housing.
