What drag bar length and risers can use stock Nightster cables?
Okay, I finally decided to do drag bars on my Nightster, but I can't visualize what size risers would work. I'm keeping the mid controls, I'm only 5'7", and I like to lean into the wind a bit, so I want my grips to be lower and more forward than stock. I asked for pics last year and only got one picture reply, but then never found out what size risers they were. Here's the link to the thread... https://www.hdforums.com/m_1969580/tm.htm. Anybody know what size risers those are? How about bar length, and whether or not I'd get to reuse all the original cables and stuff? I only want to have to buy risers and bars.
Thanks.
Thanks.
RE: What drag bar length and risers can use stock Nightster cables?
Ok, so further searching on another forum indicates that 4.5" straight risers will let drag bars clear the tank and still be able to keep the factory cables and wiring. Anybody disagree?
Now the question is bar length. I'm a little stumped here, I just went out to the garage with a tape measure and 27 seems way too short, 32 seems kinda long, and 30 seems about right. What is the normal range that people are usually happy with?
i used 6" risers and drag bars from a nighttrain. i then used a speedo mounting bracket from an '03 custom as well as the top clamp. get a dummy light indicator and speedometer wiring harness from an '08 custom and you will be set.
this set-up allows the speedo to be positioned above the tank instead of out past the bars. it clears just fine and looks way better.
sorry i dont have pics yet
I kept stock risers and cables on mine and put on a 32" Buffalo 1 1/4" bar. The brake line is kind of twisted to an S shape but everything else is internally wired. I had no clearance issues as far as hitting the tank, however I did relocate my turn signals to the fork
I kept the turn signals in their original places and used the stock wiring except for the brake line which was way too long! The clutch cable could have been a bit shorter too but it's liveable. I wired the bars internally and they are on the stock risers (or lack thereof). They're 31" wide with 5.75" pullback but I slapped on a pair of bar end mirrors too so they look a bit wider.
[IMG]local://upfiles/41462/F91F15538367439880BF4E69AF4161EF.jpg[/IMG]
ORIGINAL: joakim
I wanna know if he had any clearance issues as well because that was the reason I relocated my Turn signals. However, after relocating them, I do think they look much better. If you dont want to change your cables you shouldnt have to. It is kind of tricky getting them on they and make sure you dont pinch any wires. If you DO decide to change cables, there is a company out now making black steel braided lines instead of silver
ORIGINAL: GringoLoco
Do you have any clearance issues with your turn signals or anyhing? I thought I'd need at least a 4.5" riser. I also wanted to avoid having to put any new brake lines or cables on, but if I don't have to buy risers I guess I wouldn't mind buying a new brake line.
ORIGINAL: joakim
No sir, there aren't any clearance issues with my setup. In fact, it's not even close. If you have the time and/or money to wire the bars internally I highly recommend that too. Looks a whole lot better!
So if I'm reading this right, with some typical drag bars with a little pull back I can use the stock 1200N risers? That would be sweet, I wanted a low bar height anyways. Half of the reason I'm going to drag bars is to lean forward more into the wind, and have a more aggressive riding position. I'm also keeping the mid controls.
What is involved in doing that? Do you have to get longer wires, special bars, or just drill holes in regular bars? I just got into a bidding war for some drag bars on ebay. I have no idea what length they are, just that from tip to tip in a straight line they are ~26". I'm assuming drag bars are measured as if you were to lay the tape measure along the bar, and follow the curves (length of bar before bending). I did a rough pythagorean theorem by eyeballing it and guessed they were around 30" long. If I need special bars, no biggie, I didn't bid that much anyway.
