Voltage Regulator recall
Old 01-03-2008, 05:57 AM
thomasf59's Avatar
thomasf59
thomasf59 is offline
Default RE: Voltage Regulator recall
Took mine in 2 times for voltage reg, re-mount no parts, they were supose to hold a bracket for me.
Tom
Old 01-03-2008, 12:21 PM
dhc8guru's Avatar
dhc8guru
dhc8guru is offline
This thread is about a different recall...new in regards to the regulator failing.
ORIGINAL: agedwards63
Had it done they just relocate the voltage regulator on the frame... the 07 frames were different than the 04-06's and the voltage regulator could have got stuck in the front fender the fix takes like 10 minutes
Old 01-03-2008, 05:32 PM
domenicp7's Avatar
domenicp7
domenicp7 is offline
Brian great site. Thank-you
ORIGINAL: Brian1362
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
Follow the posted link tofind what models are affected by the recall.
Old 01-03-2008, 06:12 PM
agedwards63's Avatar
agedwards63
agedwards63 is offline
Oh my... must be brand new... just had the heat sheild recall done on the 23rd of last month... goody... wonder when they will make a chrome voltage regulator or chrome cover for the 07/08's? the old ones arent applicable to the FI's (I checked)
Old 01-03-2008, 06:30 PM
dawg's Avatar
dawg
dawg is offline
Received 3,222 Likes on 1,839 Posts
M-1200A Recall Notice
Old 05-09-2012, 03:19 PM
DavidStiebel's Avatar
DavidStiebel
DavidStiebel is offline
Question
Originally Posted by dawg
Notice removed, do you have a copy? did it include 2008 105 anniversary issue?
Ive gone through 2 batteries, figure something must be out of wack just do not have all the tools to find the problem.
Old 05-09-2012, 03:25 PM
cHarley's Avatar
cHarley
cHarley is offline
The recall had nothing to do with regulator or battery failures. It involved the front fender coming in physical contact with (hitting) the voltage regulator on 07 models.
Old 05-10-2012, 09:39 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
Voltage regulators are just temporary disposal items anyway. They fail so often, I have a spare. Just like having a spare tire for a cage.
Old 05-10-2012, 02:17 PM
Shortdawg72's Avatar
Shortdawg72
Shortdawg72 is offline
Had mine replaced at 500 miles (under warranty of course) after two trips to the dealership.
Old 05-11-2012, 01:16 PM
DavidStiebel
thanks.
Quick Reply: Voltage Regulator recall
