How many Canadians needed to change a light bulb
It only takes one.....The canuk holds the bulb and let's the world revolve around him till it pops out.![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Seriously.........Like the guy said, just remove the screw and then pull forward on the bottom screw tang real hard and the ring will pop off.
Getting it back on is easier if you notice the notch cut near the top of the ring.....Place the ring on the headlight where the notch is over the raised lip on the headlight housing and then force the bottom in place....then rotate ring to where screw hole lines up.......The raised lip on the headlight housing is about 1-2 o'clock.
I did, actually
I put those
and this "Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit".
The reason to change the bulb was that I want more light in front, but I can not put those
because of my windshiels, and I can not install those
because my engine guard is rounded. So dealership sold me $60 piaa lamp and told me it is brighter than stock. In fact it is a little brighter in the garage, but not by $60
So will have to find a way to add more headlight.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
![](http://www.harley-davidson.com/media/images/productphotos/PNA/68624_04_M_1e1f5.jpg)
![](http://a1276.g.akamai.net/7/1276/734/60284f3f2111cf/resource.harley-davidson.com/media/images/productphotos/PNA/68271_03_S_1e1fd.jpg)
![](http://a1276.g.akamai.net/7/1276/734/d7387ee789e03e/resource.harley-davidson.com/media/images/productphotos/PNA/68913_98_S_16713.jpg)
This looks like it might solve your lighting issues. The website is www.mid-usa.ca. They are based out of the greater Toronto area.
[IMG]local://upfiles/48057/18B1CB4CA84542BEA7514C89D8EFD08F.jpg[/IMG]
mrthinkshesfunny
02-25-2008 06:22 PM
