Does anyone have this velocity stack mounted on their bike?
Old 12-17-2007, 10:07 AM
cHarley's Avatar
cHarley
cHarley is offline
Default RE: Does anyone have this velocity stack mounted on their bike?
ORIGINAL: Photo
Im definately displaying my ignorance on this point, but whats "the breather bypass kit" cHarley's referring to? Is this perhaps some system to prevent excessive pressure on the filter?
The stock air filter has oil breather lines piped from the rocker boxes back into the A/C filter can. This causes an oil vapor mist to collect in the air filter, often dripping out of theA/C can, and getting sucked back into the carb. Be it a carb. or EFI, both are designed to mix and supply air & fuel into the motor not air, fuel & oil. The stock configuration is a result of EPA BS.
mrb302's Avatar
mrb302
mrb302 is offline
ORIGINAL: cHarley
ORIGINAL: BLKXL12C
Questions.....Breather and the big one with is going to keep the carb into the intake????
Huh?? Translation needed.
I THINK the question is:
With the breather kit being what it is, what holds the carb firmly against the intake?
I ALSO THINK the answer is that the mounting plate behind the stack secures to something else, maybe the breather kit, to hold the assembly on and keep the carb against the intake.
Old 12-17-2007, 10:12 AM
cHarley's Avatar
cHarley
cHarley is offline
The stack bolts to the mounting plate, which also holds the carb. in place. It's pictured dead center in the photo from the original post, between the breather hoses. The mounting plate is anchored by the breather bolts.
Old 12-17-2007, 10:56 AM
Photo's Avatar
Photo is offline
ORIGINAL: cHarley
ORIGINAL: Photo
As always, a clear concise and informative answer, which, as always, is gratefully received. Thanks mate.
Old 12-17-2007, 11:03 AM
Tommo's Avatar
Tommo
Tommo is offline
Photo....you swallowed a fooking dictionary mate
Old 12-17-2007, 11:47 AM
BLKXL12C's Avatar
BLKXL12C
BLKXL12C is offline
Ops my bad I did not click on the link. after looking at the set up I don't care for the look or set up, but that's my taste to each there on.
Old 12-17-2007, 11:55 AM
Biker Trash's Avatar
Biker Trash
Biker Trash is offline
That looks cool! I'd like one! It would sure compliment the look of my sportster.
Old 12-17-2007, 02:04 PM
Mark g's Avatar
Mark g
Mark g is offline
Then buy it up man![sm=happy046.gif]
Old 12-17-2007, 02:20 PM
Photo's Avatar
Photo is offline
ORIGINAL: Tommo
Rofls, yeah sorry about that mate. I was in the middle of writting a disertation for a degree course I'm doing for work, so I guess I guess the language was a little embellished and florid....ooops there I go again.
Actually I always talk like that. Even my Tattoos are works of prose. [8D]j/k
On a more serious note. Since my earlier post I've seen a photograph showing one of these devices fitted. It surprised me. I've seen some pictures ofair filters where an exposed cone shaped filter faces forwardand assumed these covers were to:
a) offer them a degree of protection
b) act as a scoop suck air into the cone filter.
However, the photograph I saw suggested the stack actually faces out sideways from the bike rather than forwards.
Old 12-17-2007, 02:22 PM
schumacher's Avatar
schumacher
schumacher is offline
That does look nice.
Quick Reply: Does anyone have this velocity stack mounted on their bike?
