Headlamp Help
RE: Headlamp Help
My '07 custom requires a phillips, but your might be a torx.
Once screw is out, if ring doesn't easily come off, try rotating it as you gently tug....On my '07 custom, once the screw is out I have to rotate it counter-clockwise about 1-2 inches until a notch is exposed in the ring that clears a raised protrusion on headlight housing....reverse to reassemble.
If you are attempting to replace headlight bulb, stop and post first cause there is a trick to removing and replacing those bulbs.
RE: Headlamp Help
Congrats!....Believe it or not, I had just finished changing out bulbs on both bikes when I saw your post. I figured maybe you were doing same and wanted to warn you of a few things.
So I quess I don't need to tell you about the spring clip and the little arrows on the rubber and the reflector housing.
cHarley, the guy is a Brit....Something tells me he could teach us about drinking beer!
