Well not sure on the newer since mine is a 97, but I had to change the clutch cable on mine because it was too long and one day got caught between the fender and the wheel.Luckily I was moving very slowly and it didnt do much damage.So check this out when you switch or it could be a disaster.I also need to replace the front brake tube as it is too long but I havent done this as yet.
With 32" bars the cables will be fine, I did not not have to change mine and they don't interfere with anything. Like the others said they are a little long but you'll be okay.
