NEED HELP!!!
Old 12-07-2007 | 05:48 PM
DECON BLUE's Avatar
DECON BLUE
Default NEED HELP!!!
OK, heres the deal, I bought a new 883L in april. It has 15000 miles on it since I bought it in april. Except the 1000 service I have done all the maintenance myself since the stealer where I bought it was great before the sale and have sucked since. Anyway, I live in Florida and ride all year, I do not own a car, hence the 15000 miles in 7 months. Tonight on the way home from work the clutch cable broke right at the clutch lever!! I lube it at the right times and no warning that it was about to break. Anyway, besides the 1000 mile clutch adjustment all i have done is adjust the slack in cable and all has been fine. I went and bought a new cable since the dealer would not warrenty it cause I took it off instead of having it towed in to them. Now for my question!!, The adjustment down at the clutch does not have a lock nut to break loose just a nut and spring that sets over the adjustment pushrod. It seems to me that you turn the pushrod counter clockwise till slight drag and then 1/2 turn clockwise. Is that correct?? Thanks in advance for the help. My next purchase in a service manuel.
Old 12-07-2007 | 06:20 PM
DECON BLUE's Avatar
DECON BLUE
Default RE: NEED HELP!!!
Anyone out there with a reply???
Old 12-07-2007 | 06:32 PM
schumacher's Avatar
schumacher
Haven't put on a cable myself. I'm sure someone in here has.
Old 12-07-2007 | 06:39 PM
DPete's Avatar
DPete
Big Kahuna HDF Member
Got a service manual on your Xmas list?
Old 12-07-2007 | 06:56 PM
DECON BLUE's Avatar
DECON BLUE
already got the cable replaced, not i need to adjust the clutch. do i turn the adjuster counterclockwise till slight resistence then clockwise 1/2 turn???
Old 12-07-2007 | 07:06 PM
flpops's Avatar
flpops
Turn the adjusting screw counterclockwise until resistance is felt, then back off ¼ turn. That's from the book.
Old 12-07-2007 | 07:12 PM
OldFenderGuy's Avatar
OldFenderGuy
I usually set it at 1/8 to 1/4 turn.
Here is info (and pictures) from a thread I did a year or so ago.
((This information might also be helpful for those that replace the derby cover, or remove it to add fluid, put everything back together, and then find that their clutch isn't working correctly)).
https://www.hdforums.com/m_705416/tm.htm
Old 12-07-2007 | 07:28 PM
DECON BLUE's Avatar
DECON BLUE
Thanks guys, I knew someone would help. Ride safe and keep the shiny side up.
sg9mm
06-27-2013 06:30 PM
1931jamesw
07-08-2010 04:25 PM
clayman
07-09-2006 10:23 PM
Oilslick
06-19-2006 12:45 PM
KBFXDLI
04-28-2006 12:19 PM
Quick Reply: NEED HELP!!!
