Sta-Bil
Old 12-04-2007 | 08:40 AM
Nightster 13's Avatar
Nightster 13
Default Sta-Bil
Anyone use this stuff for your fuel injected bike or other vehicles?
Old 12-04-2007 | 08:48 AM
gels55's Avatar
gels55
Default RE: Sta-Bil
Yes. Highly recommend it. It's compatible with any petrolium based fuel (even 2 cycle oil mix).
Old 12-04-2007 | 08:51 AM
Nightster 13
Default RE: Sta-Bil
so this is the way to go for my 07 Nightster, well then i will give it a shot.
Old 12-04-2007 | 10:58 AM
Fro's Avatar
Fro
Default RE: Sta-Bil
I use it religously on all my seasonal stuff: snowblower, tractor, sleds...never had a problem. Don't add it to a partial tank, make sure it is full.
Old 12-04-2007 | 09:17 PM
gambler109's Avatar
gambler109
Default RE: Sta-Bil
Anyone ever used Sea Foam?
Old 12-04-2007 | 10:01 PM
Stefan's Avatar
Stefan
Default RE: Sta-Bil
I used stabil for the first time last year. (Carbuerated) Not that my bike really sat formuch time. If you know you are going to be down for more than a month then drain your tank.
Old 12-05-2007 | 09:32 AM
Nightster 13
Default RE: Sta-Bil
ORIGINAL: gambler109
I have used Sea Foam, that stuff was great, but I used it ona carburated bike. Not sure, but that is all it is meant for(as far as fuel injected goes), its been a while though.
Old 12-05-2007 | 09:34 AM
Nightster 13
Default RE: Sta-Bil
ORIGINAL: Stefan
Iwont ride as much in the winter so I plan on putting that sta-bil in just in case, but I will probably ride off and on (once or twice every month). Better save than sorry I suppose.
Old 12-05-2007 | 10:13 AM
SemmesSporty's Avatar
SemmesSporty
Default RE: Sta-Bil
Make sure you start your bike and let some of the Stabil solution mix thru to the injectors or carb. If you fill your tank and add Stabil the carb or injectors still have just raw gas in them.
[/align]
Old 12-05-2007 | 10:16 AM
Nightster 13
Default RE: Sta-Bil
I figure I will add it and then run it, maybe ride it for a minute or two and then it shoudl be good.
