Tool Basics
RE: Tool Basics
Unfortunately, your "made in the USA" Harley comes from all over the globe.
You will need both SAE & Metric, (sockets, open/closed combo wrenches and socket drive hex/allen wrenches).
Most of the socket work can be done with 3/8 drive butyou will also need a 1/2 drive SAE socket set also.
A set of Torx bitsT15 T20 T25 T27 T30 T40 T45 T50. These will use 1/4 & 3/8 drive.
Note all of the above Torx bits are usually available in a 7 piece set (sears craftsman) except the T27. For some reason this size is not included in most sets and usually you have to purchase it seperatly.
Dont forget ratchet drive adapters to go between 1/4", 3/8", 1/2" in both directions and various extensions.
2 Torgue wrenches - 1 in inch lbs & 1 infoot lbs.
Screwdriver set
Needle Nose pliers
Diagnoal cutters
Slip Joint pliers
Adjustable wrenches in 6" 8" 10"
I'm sure there are a few more items but that should get you going.
Screwdriver set
Needle Nose pliers
Diagnoal cutters
Slip Joint pliers
RE: Tool Basics
ORIGINAL: jerryh57
Hey tiger rider, will my 07 sporty haul all that stuff behind behind it and still get good gas mileage ??
LOL
LOL
The other thing I forgot was a pair of c-clip or spring clip pliers. Its the first thing I bought when I replaced the footpegs. Also needed when replacing clutch or brake levers.
RE: Tool Basics
Make sure to get "Torx-Plus" not standard Torx bits.
Here is a great buy:
http://www.toolsource.com/drive-torx...rce=googletorx
