AHHHHHHH THUNDERMAX IS MY NEW NEMISIS!
RE: AHHHHHHH THUNDERMAX IS MY NEW NEMISIS!
ORIGINAL: Mark g
It's the main relay loc in the t max set up. pull up t maxx on your pc(the program you installed) on the left side click map configuration, then click basic settings, you will see main relay loc on the right side ,make sure it is set at 1.
I'll bet when you check it it is set on 2. the sporty won't work that way.
I pm'ed you my cell if you have trouble call and i'll talk you threw it
It tells you about changingmain relay locationin the directions for using it on a Sporty when checking the basic settings. Did you set it up so your speedo etc... are right for the bike? Did you read the instructions? Glad you got your help here and figured it out.
What a difference a day makes. I just took my initial run and WOW. Hell, even the first firing was a huge difference. No high idle, no stalling while warming up....just a nice, smooth, HD idle. I couldn't make this thing pop on deceleration either. And believe me, I tried my a$$ off to make it pop. The only think that had me worried was the little bit of smoke off my O2 sensors. But, they had anti-seize on them and also some residual oil from my grimey fingers so that wasn't a huge deal. On that note....anyone want to buy a PCIII?
AMB2710
10-11-2021 10:45 AM
SURFOR Chop
05-12-2010 10:18 AM
