Belt tention and wheel alingment all seem ok.The belt makes the most noise on deceleration.No signs of wear on the belt.The first belt lasted 18,000 miles.
Given that the first belt only went 18K, somethings wrong. You say it's not alignment or tension but it's obvious something is out of kilter. A belt ($175) and labor another ($175) is pretty expensive. At this point I would find a dealer or indy that can find out what is going on.
Two belts and the same problem indicate it's not the belt. Still under warranty? Have a dealer test-ride, duplicate the issue to them, and go from there.
Not rear rotor noise,allready checked for that.The belt cost $180 but the tow is what realy hurt,$250 for 25 miles.I'm wondering if the engine is out of alingment.The belt is sitting in the middle of the rear pully.
