Star knob
RE: Star ****
It's for putting pressure on the throttle cables, so it can be used as a 'throttle lock'..
Years ago Harley's didn't have a throttle return spring, so you had to manually open and close the throttle. When you removed your hand the throttle would stay in it's set position, so you could remove your right hand to rest it, smoke a cig, whatever, and the bike would continue moving down the road.
When Harley added the throttle return spring that automatically 'closed' the throttle when you removed your hand (another one of those 'safety' features to keep inexperienced riders out of trouble), they added the star throttle lock.
I use the star **** on all my bikes. I have them set with just enough friction applied that the throttle will remain in it's set position when I remove my hand, but I can still open and close the throttle manually without messing with the star friction setting.
Many times when Harley sells a new bike they don't even have the star lock installed (it just screws all the way out), because if used in the wrong hands someone could tighten it all the way down, andthey wouldn'tbe able to close the throttle by hand without messing with the tension ****.
RE: Star ****
Brings back memories... I the early 70's I used to ride my sportster to work at midnight. I used to challenge myself to see how far I could ride with out and hands through 7 lights and gradual turns. My record was 21 miles. Kinda crazy when I look back on it. But it was fun to try and time the lights right, and I was young and stupid...
Throttle Friction rather than Lock?
I could be wrong here but I don't think the wheel is intended to be a throttle lock under normal riding conditions, but more of a friction setting so it's either more or less sensitive to minor movement of your hand. I keep mine tightened up just a hair so the throttle doesn't move quite so drastically on bumpy roads and stuff when my arm/wrist is bouncing around. It makes the ride a lot smoother. It's still loose enough to return to idle on it's own, it's just not as sensitive. I'd be a bit leary of using it as a throttle lock because I'd probably dork it up trying to unlock it fast enough in an emergency.
