Start up in cold weather
I've seen some old posts about this. I am a newbie to Harleys, but one thing that I can't understand is how do I turn the headlight off when starting. Is this normal for HDs that the headlight goes on as soon as you turn the bike on? Seems to me that this will just drain the battery more when trying to start it in cold weather.
The last time when trying to start her up the batter just drained out and then I had to jump it with my car battery. Today when I tried to fire her up it just kept clicking away but no fire. After about 30 seconds the battery started to slow down and I could see I was getting no where. Any tips on best practices.
I have a 2005 custom.
Since the mid 1970's street legal motorcycles sold in the United States have the headlight 'hard wired' so it is on whenever the motorcycle ignition is engaged.
There is no Federal Regulation that requires the headlight to be on during the daytime, but it is a requirement in most (if not all) States.
Many States require the headlight to be on during the daytime no matter when the bike was manufactured, while others only require it in bikes manufactured after a certain date, usually somewhere between 1976 - 1978.
Here is a link with motorcycle laws specific to your home State;
http://home.ama-cycle.org/amaccess/l...t.asp?state=fl
Although it's possible, I doubt that your battery is going bad - just run down. Get a Battery Tender (a brand name charger, made by Deltran),wire the pigtail to the battery, and keep it plugged in all the time over the colder months. I think you will be very pleased with this arrangement and the results.
give the throttle 1 or 2 twists, before cranking it over, the accelerator pump will spray in some fresh gas to help get things going. Although I've only found it necesary to do this when it get's below freezing. Otherwise in general the bike always fires right up with just the choke on. SO i'd say you most likely have other issues, wether it be a battery that's on it's last legs, or possibly other issues, like maybe the carb is getting a little gummed up and could use a good cleaning.
ORIGINAL: BLKXL12C
On all bikes Harley to Honda there are no light switchs to turn off your headlight. You could wire in a toggle switch but I wouldn't.
my bikes ignition has two on settings, turn the key half way, let it click into place, and the engine will start without running lights. brake light turns on only if u touch the pedal or lever, and turn signals still work. ideal for warming up a cold engine,
turn the key one more click and everything is on
this is a little ugly diagram of how my bike works becuase i feel like my explantion is confusing.
imagine this as a side view of my ignition switch area, the big flat thing is the key viewed from the side as inserted into the switch.
![](http://i73.photobucket.com/albums/i218/prosperoenjeru/dumbass.jpg)
you might say im just not turning the key enough and it wasnt designed to be like that, but why, in the turning motion of the key does it have two specific points where you can feel it click into place. i feel it was designed. even though its not labeled on my bike.
