1995 Sportster turn signals won't self cancel.
RE: 1995 Sportster turn signals won't self cancel.
The turn signal module is secured to the front right side of the electrical bracket under the seat.
For function test remove the module. Test #1 Check for 12 volts DC at pin 2 of the connector. Test #2 Check for ground at pin 1. Test #3 place a jumper between pins 2 and 4. Right side lights should come on. Test #4 place jumper wire between pins 2 and 5. Left side lights should be on. \\; Test #5 place jumper wire between pins 4 and 6. With the left turn signal button depressed both lamps should be on. If all these test are OK replace the module. The manual states that if pin 1 is not grounded the modual will burn out. If all the test are OK then the modual is not getting speed sensor signal to pin 3.
bjpuhala
07-08-2010 11:33 AM
zrwhat
06-13-2007 11:52 AM
