Are leaking rocker covers covered by the factory?
Old 12-28-2005 | 11:57 PM
ronn39's Avatar
ronn39
Default RE: Are leaking rocker covers covered by the factory?
ORIGINAL: brohrs
Do I have to pay to replace those paper gaskets on my leaking rocker covers? I went to the dealer and they said it would cost me $180.00 to replace them.
I have a copy (pdf) of a Service Bulletin (M-1168A, 11/10/2005) that went out to dealers for 2004-2006 Inner Rocker Covers, which affected bikes built between 11/15/03 and 9/12/05. They replace the leaking rocker cover and gasket. I'm not sure if your bike is the model year affected. If it is, you might want to point that bulletin out to the dealer.
Old 12-29-2005 | 08:39 PM
mystery HD employee's Avatar
mystery HD employee
Just replace them yourself with a good quality gasket. It's an easy job and you"ll have plenty of beer left to stand back and admire the work you did. If you unconfortable with the job pick up a manual for your sporty (about 50 bucks) and you should get through the job just fine. The manual is worth the solloars spent since it gives you a real understanding about the whole bike.
HD
Old 01-31-2006 | 01:54 PM
jed's Avatar
jed
2nd Gear
I'm looking at the same problem on a 2000, 883. Got gaskets from dealer yesterday $15.00, Torque wrench$$$
Old 02-01-2006 | 12:48 PM
jed's Avatar
jed
2nd Gear
Can the gaskets be replaced without removing the tank?
Old 02-01-2006 | 03:07 PM
brohrs's Avatar
brohrs
You have to rem,ove the gas tank.
Old 02-01-2006 | 10:28 PM
Rodent's Avatar
Rodent
If you don't want to do it yourself, ask a friend or find a small shop that would do it cheaper than the dealership.
Any of your buddies that ride have a garage?
I have also talked to mechanics at dealerships that work on the side, after hours, for less money.
DanDman
02-21-2013 11:42 PM
Nikolasa1
02-15-2013 12:09 PM
fmc
07-13-2011 02:41 PM
luckyB
09-06-2008 11:16 PM
Builder
03-12-2006 06:47 PM
Quick Reply: Are leaking rocker covers covered by the factory?
