will heavier fork oil help
RE: will heavier fork oil help
Try these springs...
http://www.worksperformance.com/html/street.html
Click on dual rate fork spring kit on the left...
if you really want better front suspension bolt on a set of 03 sportster sport forks, or FXDX tubes i f you are a big guy, they have heaviersprings,and both use a cartridge inside aka sportbike, instead of harleys cheap outdated damper rods, they are triple adjustable , still available from stealers, look for a discount dealer, i paid 450 for my pair,and i ride happily everafter
Surprisingly heavier fork oil will help with bottoming out.
I was sceptical about that, but since it was time to change the fork oil, I used the Heavy weight Screamin Eagle fork oil, and it significantly reduced the bottoming out. Didn't totally eliminate the problem, and progressive springs are in my future plans, but it did help quit a bit.
