New Sportster 1200C Owner With Question
Old 10-17-2007, 09:19 PM
kawsakimx6's Avatar
kawsakimx6
kawsakimx6 is offline
Default RE: New Sportster 1200C Owner With Question
Welcome from Sunny FL.
The jump is normal, jus tput a bit more throttle behind the take off.
Oh yea, and we need a pic of your bike for refrence next time
Old 10-17-2007, 09:45 PM
SportsterDude's Avatar
SportsterDude
SportsterDude is offline
Just as a test...try launching at 5500 RPM and see if you can feel a difference.
Old 10-17-2007, 09:53 PM
carpet dude's Avatar
carpet dude
carpet dude is offline
ORIGINAL: SportsterDude
[sm=funnypostabove.gif] yea try that.
Old 10-17-2007, 10:03 PM
schumacher's Avatar
schumacher
schumacher is offline
What's a tach? [8D]
Old 10-17-2007, 10:34 PM
daddycoolj's Avatar
daddycoolj
daddycoolj is offline
Feather or even pull the clutch all the way in if you need to keep going real slow or just give a little more throttle and go. Depends on the circumstances of course. Sometimes parking lot/slow traffic can wear out the clutch hand when not used to it.
Old 10-17-2007, 10:50 PM
hogsport's Avatar
hogsport
hogsport is offline
Congrats on the new Sporty. Keep your RPM up a little, since you don't have a tach about the same as 15 mph, feather the clutch through the friction zone. You may wear out your clutch hand, but you won't wear out the wet clutch.
Old 10-17-2007, 11:40 PM
freekdawg1200's Avatar
freekdawg1200
freekdawg1200 is offline
Congrats on the new ride,Dave!I'm right downthe roadfrom you in Warminster.Get used to that new Sporty,and hit me up sometime if you wanna do a Sunday scoot!
Old 10-18-2007, 07:15 AM
BluePotato's Avatar
BluePotato
BluePotato is offline
Not that I like cruising at 10mph, I just wish I could without having to choose between the following:
1. Feather the ridiculously heavy clutch.
2. Don't feather the cluth but be shimmied all over the seat because of the lurching of the engine.
But since I do have to make a choice, I go with #1.
Old 10-18-2007, 09:07 AM
jc_denton's Avatar
jc_denton
jc_denton is offline
ORIGINAL: BluePotato
I don't know if you've done Stage 1 yet, but if you do get a goodStage 1 setup, it helps with the lugging. I gained enough low-end torque my Sportster can actually run around 2,000-2,200 now without lugging -- in any gear. Of course anything above that isn't lugging either.
Old 10-18-2007, 09:17 AM
sunking's Avatar
sunking
sunking is offline
ORIGINAL: jc_denton
Not sure what Stage 1 is. Can you explain?
Quick Reply: New Sportster 1200C Owner With Question
