Cleaning tip.
Cleaning tip.
I am sure plenty of people know this..but for those that don't. Ovencleaner rules for getting the baked on grime off. I personally like the cheap stuff found at most $1 stores.
On most surfaces (I don't recommend it painted body panels) like suspension, drivetrain components etc... spray and leave on overnight to remove most roadgrime. On engines spray on a warm engine and let sit for a few hours..
For stubborn spots, scrubbing with a stiff nylon brush will do the trick. Rinsewith water and marvel at the shine!
RE: Cleaning tip.
ORIGINAL: cHarley
That's pretty caustic stuff. Even the frame is a painted surface. I think I will stick with Simple Green, works just fine and harms nothing.
RE: Cleaning tip.
I use spray on permatex gasket remover on my cast wheels. This stuff is amazing. Spray it on,let it set about 10 minutes, spray it off with a hight pressure hose, (power washer). Removes all the grime and brake dustfrom the porus part of the wheel. Nothing I have tried comes close to this stuff.Wheels look as close to new as youcan get them. I have used it with the wheels on the bike and off.I have not had any trouble with it harming paint as I don't leave it onvery long but, READ THE LABEL, ITTHINK ITSAYS IT WILL HARM PAINT.I am very careful if the wheels are on the bike.
RE: Cleaning tip.
ORIGINAL: rwalters
i know that this an old subject but. i fell for the oven cleaner bull. never spray this on or near your engine it will etch the aluminum. i bet i will have probably $2000 and 36hrs of work before i get everything back to normal.
I had the same problem with that Greased Lightning stuff.
Try this stuff, worked on my alumninum, followed it with nano wax to seal.
