Rear turn signals lights on ?
I noticed this morning that the rear turn signals lights are not on but the front ones are along with the headlight. Aren't they suppose to be on too ? They work as turn signals only ? Only light in the back is the brake light ?
If not always on, can they be made to be on like the front ones ?
Thank you in advance.
RE: Rear turn signals lights on ?
anubisss has hit the nail on the head. The rear turn signal run/stop/turn-signalmodule from Harleyis like $46 and a GREAT investment for your safety. It gives you added running visibility at the rear and two extra brake lights to-boot. It is total plug-n-play. Simply remove the seat, unplug the wiring harness, plug in the module, tuck it down, and replace the seat - done! I did it early on when I got the bike, and feel better having the added rear illumination.
Kuryakan (sp?) has them, one for 04 up and one for 03 earlier. They are about 5 bucks more than the HDmodule but the unit hasa jumper option that flashes the brake lights quickly 3 times when you first apply the brakes. It works great and like the HD just plugs inline.
