Dyno run cost ?
Dyno run cost ?
Getting my sporty dyno'd on wed hp/tq only, 5 runs, 48.00+ 15% off , they said little more for a O2 reading, fuel/air mix ratio. they get 200.00 for a dyno tune. bike runs geat so i'll see what they say. hows this compare with cost out there? dealer is Stan's HD in Batavia NY.
RE: Dyno run cost ?
Just knowing the HP & TQ numbers aren't worth much in my opinion, other than maybe bragging rights. The air/fuel numbers are what tell you if the motor'sbeing fed correctly through the RPM range. I paid $65 for all the info., then made the necessary tuning changes myself. Just my .02
RE: Dyno run cost ?
^ I believe the carb bikes like alittle richer then efi, dan at nrhs told me to shoot for 13.5to get get the best performance andlong life for my set up. Efi is a bit more precise at fuel delivery so it can live with a bit more air. Im shooting for80hp and 85 ftlbs at the tire this time around.
RE: Dyno run cost ?
Yes, i've been reading up on it today(google)'Air/Fuel Ratio'is the the most important element to max hp., gas mileage ,engine cond. etc. just wondering why there aren't more threads on the topic, don't remember seeing any, is it because the e.f.i. bikes don't have to be so concerned about it , isn't that what re-mapping is. The perfect # is 14.7 lower is richer, better hp., less mpg, cooler temp, higher is more mpg, less hp, runs hotter, have found ideal is 12.9-13.8.Am i in the ball park here. thanks for the imput. (well i lernded somthing new today)
Druid
02-15-2012 04:40 PM
