shimming loose handlebars
Old 10-04-2007 | 07:43 AM
salzy's Avatar
salzy
Default shimming loose handlebars
after changing handlebars and tightening the new ones to spec I can still move them up and down. has anyone ever had this happen? what would you use to shim these tight? the bars I installed are new so it's not a wear issue. i have heard of people shimming handlebars but don't know what they used. anyone out there got any clue on this?
Old 10-04-2007 | 08:11 AM
cHarley's Avatar
cHarley
Default RE: shimming loose handlebars
I've made shims for that by cutting a couple of strips from an aluminium soda (beer)can.
Old 10-04-2007 | 08:29 AM
Thumper26's Avatar
Thumper26
Did you put 1" diameter or 7/8" diameter bars on?
Old 10-04-2007 | 09:40 AM
capttawes's Avatar
capttawes
Are the new bars you have not knurled? In other words....are they smooth where they clamp, if they're smooth shimming will only help a little as they need to be roughed up or grooves ground in them to give the clamp something to hold on to.
Old 10-04-2007 | 08:58 PM
salzy's Avatar
salzy
they're 1 " bars and risers and they are knurled. I'm going to change to a different set of risers( a modified capttawes set up to be exact)and if that doesn't fix it then it's soda can shim time. thanks for the tip cHarley....................Salzy
Old 10-04-2007 | 09:34 PM
valveguide's Avatar
valveguide
I have had this in the past.
ACE is the place.
Some rubber stock, maybe some longer bolts.
Old 10-06-2007 | 12:09 AM
jag1886's Avatar
jag1886
The guy that said to use a strip of a pop can is correct. All you need is a small 1/2" x 3/4" piece of aluminum or tin, lay it on topof the handle bar and put the clamp on top of itand they will tighten right up. Had this problem on my Road King, fixed it right up.
Old 10-06-2007 | 06:19 AM
dbleagle's Avatar
dbleagle
ORIGINAL: cHarley
Great minds think a like... though I used a soda can....
I promise no one can tell... I sanded all the red paint off the can before I installed them....[8D]
Charlie D.
N1265
10-02-2015 09:18 AM
CursezZz
04-04-2014 11:09 AM
TSD
08-10-2013 07:47 PM
MFarmer
03-15-2011 10:14 AM
kelton3
03-28-2008 09:02 PM
Quick Reply: shimming loose handlebars
