sporty oil filter question?
RE: sporty oil filter question?
nope, oil is only pumped into the filter, it's not sucked out. Turning the engine over will only pump more oil into the filter until air gets into the pump and it cant pump any more, and you'll still end up with a filter filled with just as much oil as before. Simplest thing to do, is pull the filter off quick and have a rag handy.
If all you're trying to do is not get oil everywhere I just use a piece of cardboard to catch most of the runoff. If you're trying to get all the old oil out, try sloshing a quart or so of keorsene everyso often in the oil tank; that helps removes sludgebuildup.
i drained the oil then sent a nail through the top of the filter. turned it 1/2 turn and drained the oil from the filter through the nail hole. caught it in a bottle then spun the filter off, and no mess. my engine has the black finish on it and it took a while to get the oil cleaned up from last time. brian i
ORIGINAL: brian falcone
smokingjoe
Milwaukee Eight (M8)
37
07-24-2017 10:44 AM
howitzer88
08-10-2013 03:45 PM
