06 883 folks with aux lights
Is there any 06 883 riders out thar that are using the Aux brake mod and some kind of aux forward lighting.
I need to pull these Harley Halogens off. 2 dealers are telling me that they are too much for the Sportsters 22 amp system ... although I find that hard to believe as a relay is supposed to be mounted when the install takes place .. anyway.... I was wondering if there was another solution.
The primary use of the lights is an cager attention getter .... 1200z dont count ....If Im not mistaken, they have a different electrical system.
Thanks
RE: 06 883 folks with aux lights
The 883 and 1200 both have 22 amp systems. To keep the current draw down I suggest using a pair of PIAA Superwhite bulbs in the aux lights. They are bright like halogen bulbs but draw less power. They are not cheap however, about $75 for a 2 pack and make sure they are "vibration rated".
I used this vendors kit.
Turns the reardirectionalsinto brake lights and directionals.
http://www.customdynamics.com/tailconversion_kit.htm
