Voltage Regulator wire very hot
Old 09-23-2007 | 07:06 PM
sewers's Avatar
sewers
Stage II
Default Voltage Regulator wire very hot
I had an issue withthe 2 year old battery on my '92 Sportster and replaced it (Yuasa sealed battery). Typical for Phoenix area, but after using the bike for a 1 hour ride the same day, I tried to start it the next day it wouldn't start. I tried it again after work and it started right up, no issues. I did a little investigating and it seems that the charging system is working OK (about 14vdc when at 3000rpm, regulator has good ground, etc.)but I noticed the wirerunning from the voltage regulator to the circuit breakeris very hot. Looks like it got hot enough to slightly melt the connector in the wire.It's obviouslynot drawing enough current to blow the 30A circuit breaker, but this still doesn't seem normal....
Anybody got any ideas?
eske29
07-12-2023 08:52 PM
tmanbuckhunter
EVO
18
03-20-2014 11:51 PM
dunderwood
07-30-2011 10:54 PM
mmgogos
07-27-2009 10:29 PM
sewers
09-25-2007 10:12 AM
