Handlebar Help
Handlebar Help
I am wanting to put 8" apes on my 07 883R and was wanting to know besides the brake line what else do I need to change or will the stock cables and wireing work? The stock handlebars are have about a 4" rise. Also if anyone has done this before how much longer does the brake line and cables have to be? Thanks for any help.
RE: Handlebar Help
Ape hangers are the **** on a sportster!You will probably have to replace both throttle lines, front brake line, clutch line, and extend the wireing. Or at least with 10" apes you do, I would guess with 8" apes you would also, I don't think there is that much give in the factory parts/routing to make it work without replacing them.
SGTGunner
10-31-2010 05:34 PM
Brackneyc
12-07-2007 08:58 PM
