lube change advice please.
[sm=helpout.gif]Going to change my lube's. Want to use Royalpurple product's. Was told to use max-cycle 20w50
in crancase, primary and trans in my 98 1200c. Can anyone shed some light on whether this info is correct,or what you would recomend if it is not. Thanks everyone for all of the help! Ride safe!
RE: lube change advice please.
You can use that oil in the engine and the primary/tranny. While HD says its "OK" to use the engine oil in the primary/tranny, I and many others believe it's better to use a Gear Oil instead. I run Modil-1 75w-90 Gear oil, but the choice of brand is up to you.
ORIGINAL: Kolni
So it is Mobil 1 20-50 for the engine oil and Mobil 1 75-90 for the tranny right?
OR....I can use 20-50 in both?
