2007 1200C with SE stage 1, D&D Fat-Cat 2 into 1, and Andrews N3 cams. Tuned with PCIII.
The look and sound of this combo is amazing. I hope to get a few pics for you guys by the end of the week.
EDIT: New chart with red curve traced in paint shop
I saw that after I posted it's there but you have to struggle to see it... I'll see if I can't play with contrast or something to help bring it out.. to help you find it, the red crosses the blue at about 3500 rpms
That's really nice. Was the blue when it was just stage 1 without cams? The n3 cams seems to help you keep most of the bottom end torque while increasing the top end. The cams seem to still be pulling at 6K rpm. If you can raise the rev limit to 6500 rpm you might be able to get a few more hp out of that it.
I picked it up after the tech who worked on it had left for the day, so I plan to call tomorrow to find out if he tried to raise the limit PCIII claims to be able to raise the limit to 7,000 rpm. As far as the cams go they claim to raise the torque curve from 2000-6000 rpms. it has been a dramatic change in acceleration... I found myself at about 75mph just after shifting into third gear... the pipes were screamin and I was gleamin
