gas mileage and gear you're in
Am I crazy, or is it true ... seems I was getting better gas mileage when I was shifting into a higher gear sooner than I am doing so now. I have been reading so much here that it is better to not shift as soon, so as to keep the engine from "lugging", and after experimenting found in fact that the engine does at least SOUND"happier" if I ride in a lower gear a bit longer before shifting into the next.I'm not talking about letting the engine whine ... just holding off a little longer before shifting. HOWEVER .. now that I have been doing that for the last week or so, I noticed I am getting worse gas mileage .. as much as 5 mpg. Coincidence?
RE: gas mileage and gear you're in
ORIGINAL: ianchris1
The lower the RPMs the less gas you are using typically. Hence the new 6th gear in the big twins getting better mileage on the highways.
The best way to enhance gas mileage and performance is to put Shell V-Power unleaded fuel in it. Try it and pay attention to your MPG on your trip meter, thencompare the results towhatever you normally use and note the differences. You'll never go with any other fuel again. It's worth the extra $ at the pump. Money well spent IMO.
ORIGINAL: seikan1
There is a happy medium. You must find it grasshopper.
If the engine lugs, it is not getting good gas mileage.
If the engine whines, it is not getting good mileage.
Now, go out and find that "sweet spot".
