Speedo Moisture?
Speedo Moisture?
Since I've had my 883R it has had moisture in the guage and I can't figure out how to get the cover off to dry it out. I told the dealer about it and they wanted to charge me labor to fix it, and well yea eff that. Does anyone know how to get that cover off the speedo? My turn signals also have moisture in them, in the front, that's not a big problem and I think they just pop off, but I didnt want to break something.
RE: Speedo Moisture?
Yup, your turn signal covers will pop off. Underneath is a slight cutout and you can slip a dime or a nickle in there and work them off, and then they'll pop back on with a little push.
The speedomether is another issue. Even if you figure out how to get it apart, you have to put it back in a way that the seal won't let it gather too much moisture again or it will just become a pin-in-the-neck routine. Do you store your bike outside? I'm trying to figure out why you have condensed moisture all over the place...
ORIGINAL: pwnzilla
Since I've had my 883R it has had moisture in the guage and I can't figure out how to get the cover off to dry it out. I told the dealer about it and they wanted to charge me labor to fix it...
I keep my bike in a garage all the time while being stored. I don't know why it has so much in there from the factory but it's really annoying to have this smudge on my guage...I'll ask (tell) the dealer to fix it when I take it in for 1k service.
Thanks for the advice.
I also keep my bike in the garage and I have moisture marksunder the speedo. It acutally fogs up while riding. I've told this to harley and they acknowledge that it can do that. They advise leaving it in the sun to dry out after a ride. I was also told that it would not be covered under warranty. They fully admit that the speedos can collect moisture due to the fact that they are NOT water sealed.
For those thinking that I am making this up, please visit the xl forums where this has been discussed ad nauseum. Also, you can see the many folks who've tried to get harley to fix, or replace under warranty and were denied. Also, the speedo can NOT be dissasembled for cleaning is what I've been told.
My advice is not to worry too much about it.
Rob
Rob
not trying to defend them, but I've heard that they tried water proofing them and found that they exploded/shattered at extreme temps. could be bs, but that's what I remember reading on the xl forums.
also, go on the softail forums and see how many fuel gauges and speedos are fogging up for them. Answer is LOTS.
And...I was looking at a real nice 06 low rider with 2800 miles on it last year. What did I notice? Water marks under the glass of both the fuel gauge and the speedo. It's apparently very common.
Rob
Rob
