Air cleaner recommendations
hammer6315 (09-21-2024)
Maybe once a week, more often if I ride especially hard or for a longer period of time. I don't ride daily, but I'll be starting to, and I'm not looking forward to emptying it even more frequently. Not a whole lot of oil comes out, but some does. I forgot to empty it after a couple longer/harder rides, and the catchcan itself started venting/dripping oil. Seems like an excessive amount of mist is venting out my breathers. Bike is an '05 with 30k miles.
I have my breather filter mounted directly above, I assume this is fine?
It's a recent addition (thanks to DK Custom of course).
I did it that way mostly because it looked good, but I could easily move it below instead if that is "better" for the escaping air/oil/whatever?
DK Custom (09-22-2024)
tempocyclist (09-21-2024)
Received 4,216 Likes
However, it is a matter of person preference and whether there is room between the bottom of the tank and the top of your air cleaner.
The one main advantage of routing the hose and filter above the air cleaner would be having gravity on your side.
Install looks great!
Feel free to contact us with any questions you may have.
Ride Safe, Ride Free.
Shelly
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
In that position it looks like the misty air would be filtered and escape but wouldn’t the oil just sit in the tubes now ?
The following 2 users liked this post by Andy from Sandy:
hammer6315 (09-21-2024),
Alright, after taking advice from strangers on the internet 😂 I relocated the breather from above (see photo earlier in thread) to below my air cleaner assembly.
There was maybe a tiny bit of oil residue in the tubing when I removed the old setup. Nothing major, but then again I hadn't exactly put many 1000's of miles on it like that. I'll keep an eye on it and see if anything starts to drip out of the filter. If anything, the switch from above to below gives a little extra peace of mind.
So then I wheeled the Iron out for a short blast, you know, just to be sure! Cheers! 👍
BlueridgeXL (Today)
