07 883 exhaust
07 883 exhaust
I would like to change the stock exhaust on my 07 sportster and make it sound like a Harley. Is there any pipes/slipons out there that can replace the stock exhaust without the dealer having to analyze and change a chip in the fuel injection and or any other costly modifications.
Thanks
Thanks
RE: 07 883 exhaust
You have an oxygen sensor in each the exhaust pipe. As long as you're just changing the MUFFLERS to after-market slip-ons, you shouldn't need a remap and you won't disturb the oxygen sensors. If you change outthe entire pipes make sure they accommodate the oxygen sensors and you will most likely require a remap if changing the entire pipes.
Delaware 1200 Custom
08-11-2006 09:04 PM
