Do I have S.E. IV?
Soft comfortable ride on a Nightster LOL.
But seriously, tires "ain't gonna do it".
The front fork springs are very soft as is.
The rears shocks have limited travel, I believe only 2.75 inch fully extended.
Then there is the thin seats.
I'll say Nightsters ride rough
So, it may be you are bottoming out the suspension and are reaching the discussions of many on this forum
Yep, aftermarket fork springs (Progressive) and setting your front sag is well worth the effort and cost.
Many install the longer 12.5 inch rear shocks (which was factory length for Europe). and costs can range from used "take off" to Ohlins.
Noting with longer shocks one could say you will lose your visual stance/ bobber look.
So, first set, set your front and rear sag an see where you are at suspension-wise.
Then decide on suspension modifications.
However, a thicker seat may also be the first answer to your comfort question.
And , to answer your question, I use the OEM HD Dunlops, as I don't race around (corners or high speed), or ride in rain.
I also use the factory PSI suggestions 30 front, 38 rear.
Lower pressure would also function as a softening of your suspension, in a straight line.... but on face value I do not recommend that.
Good luck, enjoy your N.
The Shinkos are a decent tire, especially considering price. In my experience they wear quickly but again, at the price they seem to be worth it.
John Harper (07-01-2024)
The following 2 users liked this post by random155:
John Harper (07-02-2024),
Paintslinger16 (07-01-2024)
96hugger (07-02-2024)
