Engine oil in the primary issue
Aloha,
after riding hard my 1995 Sporty with 1200 conversion I found today an big oil spot under the bike.
It came from the gearbox vent under the seat.
After checking the primary I figured out there was 500ml (1/2 quart) engine oil over the limit.
I normally use the Rev Tech 20W50 engine oil and the Rev Tech Sportster Trans fluid in the primary/transmission.
I know the difference betwean the taste of engine an transmission oil.
It's definitely engine oil in the transmission.
While I'm the only mechanic since the last 29 years I know there is no bad filling.
So my suggestion is a bad sprocket seal.
Am I right with my guess?
Anybody had the same topic in the past?
What about the engine/trans, is it half quart low?
