Gearbox rooler bearing
You don't have the bolted transmission panel that is shown in your video, which is referred to as the trapdoor. If you have a 2004+ you're going to have to split the cases, nothing else you can do.
It sucks having to do all that work to replace a $25 (?) bearing, but that's what has to happen. Bummer for sure.
John
John
It's the one in Malta that was badly corroded by sea water, he had to do a ground up restoration job. I don't recall the motor being stripped down during the restoration.
dijsil (06-16-2024)
nope motor wasn't stripped down as it was fine it only covered 5k km since then and has a total of around 12k
Rob Roy's Revenge (06-21-2024)
John
John
John Harper (06-16-2024)
maverick31210
04-04-2018 12:21 PM
