Battery discharging
Battery discharging
Hallo Sportster friend.
I still have a problem with my Voltage supply. i take out my regulator and cleaned all connection's. so there are now in a good condition. I recharged my Battery and the voltage is 12.32V then i start the engine and measured the voltage on the Battery which show me 12.67V then in speedup the engineand the voltage just went up to 12.77V. I didn'tget the voltage of 14,5 or even higher. So what can i do to check which part is not working well. I read in so many post in the forum that to measure the out going voltage from the stator. But how can i measure the outgoing voltage from the stator as long i connected with the cablefrom theregulator. Coz I'm believe that without regulator I can't run the engine. question: The connection with the doublepin is't negative Masse -? and the connection with the clip on is't plus wire??So what can i do. need really help.
Thanks
helmut
Thanks
helmut
