Mini apes and 6" riser?
Old 08-28-2007 | 12:40 PM
007nightster's Avatar
007nightster
Default Mini apes and 6" riser?
How will this work i have a nighttrain bar setup with the 00-03custom speedo bracket and i have these mini apes orderd from licks cycle of there new Z top bars, i used to have 16" chubby apes so i have all the right cable lengths and wiring heres a pic of there new bars look pretty nice
http://www.lickscycles.com/catalog/i...s-ZTopBars.jpg
Old 08-29-2007 | 10:39 AM
007nightster
Default RE: Mini apes and 6" riser?
nobody?
Old 08-29-2007 | 10:43 AM
kawsakimx6's Avatar
kawsakimx6
should work fine. i think
Old 08-29-2007 | 10:45 AM
Live2Ride's Avatar
Live2Ride
Banned Camp
I'm not sure I understand what you're question is. I just ordered some mini apes for my 1200 and I was told getting the cable lengths is no problem. The issue could be the brake line. It might have to be bent to make it fit. So I'm thinkin' that's the only issue you could run into as far as cables go. The length you have should be fine. Those Z-bars are nice. I was thinking about getting a set, but decided to go with mini apes. I'm getting Roland Sands bars for my Softail, which kinda have the Z-bar look, so I wanted to change things up a little for the Sportster.
Old 08-29-2007 | 11:39 AM
128auto's Avatar
128auto
Use your stock speedobracket that came with your Nightster unless you want the Z bar sits on top of the 6" risers, looks weird.
Eagle15
06-18-2017 10:54 PM
mills
06-10-2011 05:52 PM
brkbstrd
10-12-2009 08:00 PM
Lundee
12-31-2008 07:23 PM
devils haircut
07-18-2007 07:54 PM
