Oil - Oh No Not Again
First, This post is Not About Oil Brands but about V-Twin Oils. It's not about my Amsoil is better than your XYZ brand. It's about the difference between V-twin synthetics and automotime synthetics.
If you're happy with your oil fine. Stay with it.For those thatbuy into the marketing hype that you need to have a special V-Twin oil in your MC this might be worth reading.
Is your $9+ per quartV-twin oil really any better than $4 auto synthetic oil? For those of you that venture outside the sportster section of this forum you may be familiar with Pocojc, he probably knows more about oil than anyone on hdforums and he comments on the subject in this thread.
https://www.hdforums.com/m_2117248/tm.htm
RE: What Oil - Oh No Not Again
ORIGINAL: xxxflhrci
Will your bike run longer on 9 dollar synth MC oil or 4 dollar synth auto oil than mine will on $1.99 dino? I don't know, but I am going to find out. I'm at 67k on Twin Cam. I let you know when she pops.
The difference between V-twin formulated formula oils and other motorcycle/car oils is Viscosity...
V-twin engines typically have roller bearing cranks which require the higher viscosity oil (HD dino oil actually has the highest viscosity rating with SYN3 coming in second).
The biggest difference between motorcycle oil and car oil isagreateramount of anti-corrosion additives in the motorcycle oil...they assume a motorcycle has longer periods of downtime inbetween usage so a need to fight off corrosion caused by moisture build-up. People who find there oil is milky is due to high humidity building up water in the crankcase which if you ride the bike on a regular basis, the water evaporates but if you let the bike sit in a moist area, climatic changes will cause water to build up fast. If you use a quality motorcycle oil, it will coat the internal engine components with corrosion inhibitors which will keep the rust away. Large quantities of water are not going to evaporate easily and likely there will be damage unless the oil is replaced.
The real question you have to ask yourself is if your Sportster is worth the extra $4 a quart and the peace of mind that you are using the right product.
ORIGINAL: dhc8guru
bobbyd3
Oil Archive (no new posts)
17
06-07-2022 03:02 AM
