Evo 1200 Wiseco Hi Comp Pistons
Howdy,
I have a stock 99 1200C sportster that is under the knife, and currently operating on the motor. I already have a set of Andrews N4 cams and dynatek 2000i ignition that will be running. I am currently in the process of replacing all gaskets, including the base gaskets. Whilst having it apart, I am considering upgrading the pistons to a higher compression piston. Wiseco has a domed piston upgrade, that would increase the compression ration to either 11.4-1 (per J&P Cycles) or 10.5-1 (per Wiseco). The item in question is Wiseco part# K1685. I am wondering if anyone has run a similar combo, and if it is advantageous to upgrade. Any feedback would be tremendously appreciated.
Sounds like a cool project. I’d think hard about skipping the 11:4 pistons with the AZ heat and mid-grade octane, the N4 should work well with 10:5.
I’m new to the HD & evo world with only one build (not completed) under my belt, so hopefully more experience will chime in.
Hammer performance has a nice tech library on their site, helped me out big time, love the Dan.
Double check the base & head gasket selections, there’s a bunch of options to get the correct squish.
I am planning on going 93 octane, but definitely wanting to avoid race fuel. The 10.5-1 is ideally what I am after. With the cylinders already pulled off, it seems like a fairly easy upgrade, since the ignition timing will already be adjustable, just trying to decide if the juice is worth the squeeze with a $400 set of pistons.
Moltenmetal (12-05-2023)
John Harper (12-05-2023)
