Very loud tapping randomly...exhaust leak, lifter?
Old 12-02-2023, 12:38 AM
OCSpringer's Avatar
OCSpringer
OCSpringer is offline
We'll still no luck but I think I have finally identified the real culprit. It's still the lifters. I was finally able to get a good listen with a mechanics stethoscope and the ticking is coming from the pushrods at the rockers. So my guess is the lifters are collapsing for some reason and it likely is not the lifters, but an oil pressure issue. I'm swapping out the rocker boxes tomorrow anyway as the S&S boxes are hitting the battery terminal and I am not sure how to rectify that just yet, if it can be rectified.
  #72
Old 12-02-2023, 04:47 AM
BlueridgeXL's Avatar
BlueridgeXL
BlueridgeXL is offline
The intermittent tick you have is an odd one for sure. I’m new to the evo and my best advice is not to take my advice. However, I think swapping to stock rocker boxes will be a massive help in troubleshooting. A pressure issue would tick at all times when hot, so what’s causing the intermittent bleed down?
I was sure you had it pinpointed correctly to the lifter, but you’ve been down that road.
Like the wise old saying goes “ain't no wrong and right, just right and learning”.
Thanks for sharing, definitely going to help me and others.
John Harper (12-02-2023)
  #73
Old 12-02-2023, 06:48 PM
OCSpringer's Avatar
OCSpringer
Well new (old) rocker boxes are installed. Top end is much quieter with these rocker boxes overall. Issue still persists of course.
I like these rocker boxes better actually and will keep these on. They are a little smaller footprint and with some of my other mods the S&S rocker boxes were a little tight.
Well I guess the next step is to pull the oil pump and have a look there. If nothing pull the cam cover and lifters again and start tracing through the oil ports and see if any are clogged up.
  #74
Old 12-02-2023, 09:29 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,847 Likes on 1,260 Posts
IIRC, you are using aftermarket lifters? The valve is not the issue?
John
  #75
Old 12-02-2023, 10:22 PM
OCSpringer's Avatar
OCSpringer
John
Hy-Lift Johnson lifters brand new. I actually believe it is the rear intake lifter losing pressure.
  #76
Old 12-03-2023, 01:40 PM
OCSpringer's Avatar
OCSpringer
Cleaned up the garage today. I like to clean everything up when I finish one tear down and start another. Bike looks great too bad it runs like crap. I'll begin tear down number 3 to try and resolve this issue after lunch I guess. I have a target this time though as I am pretty sure it is the rear intake valve lifter collapsing. I thought it was the exhaust valve but with the new rockers on it is much quieter up there and now it is easier to hear where the tick is coming from. Maybe it's an oil passage blocked or the pump is mucked up or something. But I am convinced it is still a colapsing lifter. The question is why. I replaced the entire oiling system when I rebuilt the motor. I did not blow out all the oil passages though. That may have been a mistake. I did find an old piece of paper gasket in one of the camshaft bushing oil passages when I first tore down the motor originally.
At least the bike looks good in a clean garage.
Pretty happy with the end result once this lifter nonsense gets resolved.
John Harper (12-03-2023)
  #77
Old 12-03-2023, 02:12 PM
QC's Avatar
QC
QC is offline
Received 19,798 Likes on 9,865 Posts
Been following along.
Love that springer front end.
  #78
Old 12-04-2023, 04:41 AM
BlueridgeXL
Bike looks great. Aren’t the lifters a fed from common feeder? Sorry for the questions while you’re in the middle, I was thinking it would have to be in that specific lifter bushing as bouncing pressure from the oil bypass should hit all four.
  #79
Old 12-04-2023, 09:25 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 13,795 Likes on 5,893 Posts
Off topic but man, that's a great looking Sporty you got there. I hope you get it to run as good as it looks.
  #80
Old 12-04-2023, 11:12 AM
OCSpringer's Avatar
OCSpringer
They are all fed by one passage I believe. If it is an oil issue then my guess is it will be the pump or maybe the bore is damaged in the case. The only way to know is just tear it all back down. I am going to remove the oil pump and go through that before I pull the cam cover or anything. Maybe just cleaning out the oil pump fixes the issue.
Quick Reply: Very loud tapping randomly...exhaust leak, lifter?
