first oil change and primary/tranny
I am about to change my oil.I went today to purchase my oil "3 quarts", tranny fluid "1 quart", oil filter, and all my new seals and gasket. I was just wondering why they gave me so many seals? I know one is for the primary cover, one for the oil filter, and the other two I think they go to the drain plugs?
RE: first oil change and primary/tranny
I wouldnt pull the primary cover off..........after you drain it.....make sure the bike is almost level(use a block of wood under the kickstand if you dont have a bike jack) but be careful and done let the bike turn over.
I removed the smaller chain inspection cover and added 1 qt of fluid and went that route per other members suggestions and I found it to be alot easier
wayne
wayne
I am about to do the same, I have my oil and tranny oil still got to get the filter but didn't know about seals?....what seals..? I have my service book coming so will not do anything till it arives, this will be my 5000 service any info would be greatly appreciated
ashmarc
01-17-2010 12:02 AM
gilmour68
05-31-2007 10:13 PM
