Would baffles make a difference?
Si I had my 2009 883C stock and put an FP3 tuner on it, ran beautifully, put Cobra 909 Speedster exhaust and a SE Stage 1 air cleaner on and retuned with those items. Now it idles like it's cammed, ( which sounds really cool, but I know it's not supposed to.) Also runs really choppy. If I'm accelerating it seems smooth, but if maintaining a steady speed, it seems like it's missing or something. I have a message in with Vance and Hines, but I'm not so sure the tune is the problem. Double checked the air cleaner to make sure no leaks, plugs are brand new and gapped properly. I'm wondering if the baffles in the pipes are causing a problem? There isn't really anything crazy going on and it's a simple stage 1, no engine work. I'm stumped. Any ides?
it wasn't "exact", they had Cobra Speedster shorts, std baffle, high flow air cleaner. Not 909's, but should be the same. I never had problems with a stage 1 before, they are usually a no brainer, that's why I thought it might be mechanical, but I checked everything I installed and it should be fine, no leaks. That's why I was thinking baffles, maybe too much back pressure? Never heard of that with just pipes and an air cleaner, but who knows.
I'd start with getting rid of that tuner and exhaust.
The Fp3 is OK for stage 1/ exhaust and intake tuning but seems most people have to go back and forth with V&H making adjustments and running auto tune sessions many times to get a decent tune. Also the Fp3 is known to have poor tuning/ fuel control if you ever do anything more like cams. And those short pipes aren't doing you any favors in the sound and performance department IMO.
2500hdon37s (07-12-2023)
In the scheme of things both tuners write to the same ECM places. If V&H have done a dyno tune on a setup then their map ought to work. There is plenty of satisfied customers who don't even bother with autotune but their bikes run fine.
If Dynojet haven't dyno run a setup then it is likely similar results will be exhibited, IMO.
Received 1,638 Likes
JRider1807 (07-18-2023)
