digital speedo
Received 1,638 Likes
Here is the Dakota, it is plug and play for 2004 to 2022 Sportster models. UYou can change the colour to suit your mood.
Here is the Koso with digital speedometer analogue tachometer, it too is plug and play for 2004 to 2022 Sportster models.
Here is H-D's speedometer / tachometer combo, the part # is 70900100c.
HD has three versions, two is for CAN bus bikes, those from 2014 Sportsters and up. For your 2008 you need the other one part #70900274.
https://www.harley-davidson.com/us/e...ter/p/70900274
ETA: Be aware the HD speedo marries to the bike after the bike has been driven for 30 miles. It has to be programmed on the bike to get the mileage from the ECM before fitting. All of this is in the instructions that come with the speedo.
The following 2 users liked this post by RKZen:
benjamin lorenzo (07-07-2023),
Danxtian (07-08-2023)
I have installed two and on the 2017 it was more difficult with where HD have put bits.
On a 2008 the fuel pump is a game of tetris to get out of the tank. It does require patience to wiggle the pump into exactly the right places for it to come out.
The fitting of the sender itself is then very easy with it replacing the low level switch already there.
Then you just have to get the pump back in the tank!
You can read the installation instructions here - https://serviceinfo.harley-davidson....5?locale=en_US
