Best way to repair scratches in frame paint?
Looks like good stuff. Although I wouldn't expect anything near the 250 deg rating that high above the engine, the heat resistance is probably helpful for something that goes through many heat cycles.
They make a frame paint you can buy but I would just use the black enamal model paint, clean it up with some acetone on a rag, sand out any rust spots. You can get black enamal paint in a spray can if you want. Just make sure you cover everything up that you don't want to get paint on.
Model enamel paint. I use Humbrol enamel paint for touch up. As it is generally for models it comes in a small tin but it goes a long way.
The two bikes I have here have suffered where the tank seems to rub the frame. I put a piece of duct tape on the frame to try and protect ti.
Received 1,638 Likes
bstahlman (07-04-2023)
