Jagg oil cooler, Arleen Ness big brake kit, stock cams are enough torque for me
Thanks!.. So much to take in with the photos!. I was thinking you probably kept the stock cams. I'm planning much taller gearing and will keep the stock cams also, but with some head work. Any problems not running a belt guard?
Running a bigger front sprocket myself. Also did some light porting... noticeable difference. No problem with belt so far though I run it slightly loose ...
