HELP new battery but no power
You have given very little information, IMO.
Is it keyless ignition?
If the fob doesn't work you would be invited to enter the pin number.
When you turn on the ignition what exactly happens? If with key what happens when you put run / stop switch to run? Does anything work?
It's keyless just have the fob.
I click run and the bike does absolute nothing.
All I have is the red alarm flashing so there is power going through
Received 6,055 Likes
Again, if the fob is not working the speedo will call for the pin to be entered.
So you put the run / stop switch to run and the ignition doesn't come on, no headlamp, and you don't get the message in the speedo after a few seconds?
If you press the trip button on the left hand control with the run / stop switch to stop does the speedo display mileage?
I have no ignition no headlamp nothing
and theres no messages on the speedo
Pressed trip button and nothing is coming up
