Primary Chain Adjustment
I'm looking to check the adjustment onthe primary chain on my 2005 1200XLand would appreciate some advise.
In the service manual you get the hot and cold specs for checking the play in the chain, but the diagram would seem to say that the range of play is measured fromhow lowchain can be moved down fromits at-rest position (after finding the tightest spot), tohow high. So ifgoes down 1/4 inch and up 1/4 inch that's 1/2 inch of play.
I got the Fix My Hog DVD and it shows them checking chain tension by just applying upward pressure and checking the play.
So my question is, which way? Up AND down, or just one way? Further, when checking the play, how much pressuredo you apply? Just enough to meet resistance, or enough totry "stretch" it?
I'dappreciate some advise.
RE: Primary Chain Adjustment
I hear ya man...those specs on the primary chain are VERY confusing. If you look at it though, the acceptable amout of "play" in the chain is pretty broad.
I usually just feel the chain, plus knowing the input I have from riding the bike, then make an adjustment. I generally do this at the cold temp specs. Hot would be better, but my fingers don't like hot metal.
Some folks will tighten the primary chain up until it starts to "sing" and then back it off just a tad. I'm not sure that's not a good way to go about it.
Sorry to not be more help, but that's worked for me so far. And the dealer isn't gonna do any better, because their only expertise is to read the same manual you're reading (assuming they can read) and then they have the same information you have.....but less concern about the primary chain being adjusted correctly.
All you need to do is ride the bike, get it warmed up. The reason for that is because the chain will actually change as it heats up. So for complete accuracy check it hot. Once all that is done, jack your back tire offthe ground. Now pull the plugs out, put the bike in fifth gear.Pull the inspection cover off, now begin to rotate your back tire until you find the tightest spot in your chain. That is where you want to make the adjustment. Without touching the chain just eyeball it. Where ever the top of the chain is setting that is where you want the bottom of the chain to be when you push up on it. Basically you want the chain to be able to move the width of the chain. That is the right way to do it. It sounds like a lot, but it does not take long, and you know it's right.
