Ignition Module???
RE: Ignition Module???
It's super easy. Follow your wires to the plug. Unplug it. Take a pin and paper, where the wires go into the plug the colored wires are numbered. Just list color with number.Take small flat screwdriver and pop the orange cover out of the plug. You will see the small clips inside the plug. Just take screwdriver and pull the little clips back and pull wire from otherside. Simply put knew wires in appropiate spot, put orange clip back in. No problem. YOU CAN GO IT!!!!!!!
