Intake seals cost including labor?
Im wondering how much labor was involved and total cost to have the intake seals done at a shop or dealer? I have a 2000 sporty with a cough and pretty sure its the intake seals, just no time atm to dig into it. I might get it apart, then I'll get sidetracked, and parts will get lost, and u know the drill... might just "have it done"! (Unless someone says it is easy, and fast DIY job)
Probably takes less than an hour, carb pops off easy, just set it aside on a stool. Don't need to even disconnect cables. Pull vacuum and fuel lines, inspect and replace as needed.
Need a 3/8" stubby allen wrench and some red grease or dish soap I think factory manual says. Easy peasy job. Very important to do for sure. Yours could be 22 years old for all you know. Probably have to pull off the fuel tank, another two bolts that are easy to do. Basically 6 bolts, 2 for the the aircleaner, and four for the manifold. Don't mix up the manifold flanges they should be marked for front and rear. Leave manifold bolts a bit loose till you fasten the carb back, then only hand tight after that so manifold is aligned with carb and backplate. The manifold actually moves in and out of the flanges as the cylinders heat up, moving away from each other.
Reaching the top bolts at the end is the only tedious part, the rest is easy. A ball end stubby Allen works best for those upper manifold bolts. You can get a Bondhus on Ebay.
It's an easy job, so don't take any bs about it at the shop. I think replacing them is one of the most overlooked solutions to carb cough.
John
John
TexasScooterTrash (04-02-2023)
thanks guys, I think from everything I read the seals would be #1 to do. if it's ignition, I'll have to deal with it. seems more rear cylinder than both so Im hoping that means the rear cyl intake seal but we'll see. I'll go ahead and take a crack at it, already picked up the seals at HD and watched a couple youtubes
Carby Hamcan (04-06-2023)
Do not overtighten those bolts when going back together with it.
John Harper (04-02-2023)
another note on installing seals is to lube them with grease or dish soap. i prefer dish soap because it evaporates off. the soap or grease will allow the seals to glide along the mating surface without getting bound up or tearing. only intake seal leak i've had was the first time i installed the seals dry.
John Harper (04-03-2023)
