Intake seals cost including labor?
it's 1/4 allen for the intake manifold flange bolts. ball-end 1/4" allen or a 1/4" stubby bit like you mentioned is what i use when replacing seals. yeah i changed the lowers to hex as well haha.
another note on installing seals is to lube them with grease or dish soap. i prefer dish soap because it evaporates off. the soap or grease will allow the seals to glide along the mating surface without getting bound up or tearing. only intake seal leak i've had was the first time i installed the seals dry.
thanks guys, I think from everything I read the seals would be #1 to do. if it's ignition, I'll have to deal with it. seems more rear cylinder than both so Im hoping that means the rear cyl intake seal but we'll see. I'll go ahead and take a crack at it, already picked up the seals at HD and watched a couple youtubes
Gary1 (04-03-2023)
Kentp
04-06-2008 08:25 PM
